L2350 Transmission Cover Removal
KOMAS L2350
Backhoe, Rear Blade, Box Blade, Brush Mower
Dec 29, 2016
Denman Island, B.C.
The yoke to shift Reverse has broken. Am trying to remove cover on Transmission to replace. Does anybody have access to the manual that shows the steps. I have the bolts out of the cover but it now appears I need to remove spring pins in shifter shafts to remove. Look forward to hear from somebody who has gone there before. :)
6,122
Haven't worked on that exact model, but I did email you a link for the WSM which should help you out.
chuckv9779
Kubota l2350
May 16, 2024
Excellent to here! ;)
I purchased a L2350 and the transmission SPEED CHANGE COVER is broken and i think one or more of the forks are broken im trying to get it in neutral without causing any more damage to see if i can get it to crank before i put to much money into it. all 3 of the shift rods are all the way faward and im curious what to bring back first so i dont break anything thanks
6,122
Order of movement doesn't matter, they either move or the don't.
