L225 front wheels
Top Fuel
L225
Aug 20, 2023
CT
Hi' I'm new to this forum and just picked up a L225 2wd. I'm looking for a 4 bolt front wheel. I am also looking to replace or rebuild lift cylinders for the loader (they leak down within 15 minutes) any info on parts would be greatly appreciated. Thanks
10,963
For the wheels try miller tire or hey wheel.
For the loader, that's semi normal for them to bleed down.
In order to give you any more info need the loader model number and serial number if you can get it.
rbargeron
Jul 6, 2015
1,185
260
western ma
Four-lug 15" wheels (32210-11640) for a L225 are hard to find. Places like Messick's make an effort to find wheels that will fit -not sure they'll look like the originals....
Assuming yours look like this? Original tire size is 4.00-15 for the L225.
Measure your bolt circle diameter (bolt-to-bolt across the center) - compare that and center hole size to available wheels - offset is not critical if the width between beads is near 4" +/- .
Here's one from Miller tire that may be close. Another possibility mighty be to get repairs done on the old one? What's its condition?
