I had the dreaded oil light on a L2201 I recently bought. Tore it down and replaced the missing cam plug. Just used it for the first time after the repair and after discing for about an hour, my oil light came on again when the rpms were low. If I revved it up the light would go back off. A few days later, I hooked up the oil gauge. Had almost 70 psi at idle. Let it run for about 15 minutes at 1000 rpm and was still showing 60 psi. What do you guys think? Bad oil pressure switch?
