L2000 Bush Hog 2246QT FEL
Rjsimms
L2000
Jan 27, 2020
Vancleave MS.
Hello all. New Grey Market owner of a L2000. I like the little tractor a lot. I have found a Bush Hog 2246QT FEL at a reasonable price I believe. Was wondering if it would fit my L2000? Bush Hog web site says a 1846QT would work. But both have the same directions and operating manuals.
Thanks in advance.
5,125
It should fit it fine, it's just going to be really slow as it has bigger cylinders and requires more GPM to lift at speed.
Rjsimms
L2000
Jan 27, 2020
Vancleave MS.
Thank you Wolfman. I was thinking the same thing, based on the data sheet for both.
Maybe a newbe question, but where would the hydraulic lines from the FEL hook to the tractor?
5,125
On most older Kubota's it requires cutting the line that comes out of the pump, and welding fittings to each end of the lines, that is if it's not equipped with a junction box, which I don't know if your model has one or not.
Pictures of the lines from the pump back will help us determine that.
You will also have to add a return/tank line that will go to an adapter that will feed into the fill plug location.
