L185 ignition switch
shooter56
kubota L185 w/fel
Sep 25, 2015
150
CT.
I was having problems starting the tractor and narrowed it down to the ignition switch. I have had the tractor for at least 4 years and I've never used the lights because they didn't work , I really wasn't worried about it. So back to the switch. I took it out and it has 5 terminals but all the wires were on 3 terminals? The switch is a universal I think because it says made in Mexico on it. No wonder the lights don't work!
So I am looking for a diagram for the switch so I can get the right one. If anyone has that info I would really appreciate it.
Thanks pat
8,309
Go to KubotaBooks.com and download the WSM, it has the schematic in it. ;)
shooter56
kubota L185 w/fel
Sep 25, 2015
150
CT.
Thanks, great site for reference over there.
Now to find the right ignition switch. It appears kubota has a proprietary switch for the l185.
$ 65. To $85. I guess that's why there was a universal switch in there.
007kubotaguy
B7100DT L245DT JD 2355
Dec 23, 2012
665
272
Herald Calif.
Hello
Send me a PM with your shipping address and I'll send you a good used switch.
Lance
1,760
If you send a PM I can send you schematics
shooter56
kubota L185 w/fel
Sep 25, 2015
150
CT.
Thanks for the kind offer on the switch and schematic.
Great people in the group!
1,760
I have attempted to send the schematic to you but let me know if you didn’t get it. And send a PM with your email address since I forgot to ask last time.
8,309
If you click on his name you can email him. ;)
1,760
I use tap a talk and see what you’re saying but I thought that was sending a PM not e-mail. You are saying that goes to the person’s actual email address?
1,760
On an iPad and tap a talk it does not show those options. Using the iPad and safari browser (instead of tap a talk) also does not show an email option.
I’ll look on a pc (mine has to be repaired) when I get access
shooter56
kubota L185 w/fel
Sep 25, 2015
150
CT.
Russell, thanks for the schematic, once I get a ignition switch it will be a snap to fix up the wiring in the kubota.
1,760
Glad you got the information.
If you need it, the wiring harness is probably still available from the dealer. There are two halves.
shooter56
kubota L185 w/fel
Sep 25, 2015
150
CT.
I can fix up the old harness without trouble. I am still looking to get a ignition switch, I guess I'll just bite the bullet and get a new one.
shooter56
kubota L185 w/fel
Sep 25, 2015
150
CT.
Thanks Lance for the kubota ignition switch!, cut the wrap on the harness back. Replaced the ends installed the switch it works. Even have lights , damn. Thanks for the help.
1,760
Glad it worked out well for you!
