Okay my steering box gave out...
Lucky for me it had enough left to get it into the barn. Removal of the steering wheel, console, fuel tank then removing the gearbox was not so bad. Lucky for me my neighbor had a steering wheel puller as well as a pitman puller. Both of these are (almost) a must IMO. Disassembling the gearbox I found about 3/4 cup of water which must of had something to do with the failure
as well as a worn steering column bushing under the steering wheel. Also had just about every ball bearing from the upper and lower ends rolling around in the bottom of the case.. lucky for me I still had some in the worm tubes or would have had to drag it to the barn somehow. So I have it all broke down now.. the shaft is gouged along the worm area where the ball bearings travel. The teeth on my horizontal shaft seem fine and my case is not cracked so now onto my question>>>
What parts do I need to order to rebuild this thing? Here is what I think I need and just wondering what I am missing besides the 80w-90w gear oil and the 6 pack of my favorite brew
1 Steering Shaft With Ball Nut Assy
Selector Shaft Gasket
Upper & Lower Bearings
Horizontal Shaft Seal
4-5 Shims
New Woodruff Key
Steering Column Bushing
That's all I can think of.. anything else I might need I did not see in my IPB? Does anyone (Vic) make a packaged rebuild kit for this repair or do I have to order it all separate? And Vic if you want to shoot me a cost invoice so I can start saving please go ahead and do that
Any other advice or thoughts before putting this back together would be nice. Taking pictures along the way and may post after I am finished.
4-5 Shims
New Woodruff Key
