Went to go drain the radiator in the L1500 to replace it with actual antifreeze 50/50, and saw the petcock right above the right side frame where nearly impossibly to not drain into the frame.
I remember reading a post on here about someone complaining about the same thing but for the life of me cannot find it. I think one of the regulars like Daren Todd had a suggestion for making it easier. Seems like I need some kind of right angle diverter to put on there and am looking for ideas. My idea thus far was to wedge a spade in there as a make shift diverter into a bucket
Also, i'm soaking the petcock because i could not turn it. It also appears to have a cotter pin on the petcock? Do i have to remove the cotter pin? Seemed strange. Wasn't sure if the thing was just rusted closed or I have to try to get soemone with tiny hands to try to remove the cotter pin in the impossible location.
Also, once I drain the radiator is it proper to also drain the block using the petcock on the right side of the engine? The manual's i have do not indicate proper procedures for coolant replacement, presumably because it is too easy, just technical details about how the cooling system operates.
Thanks for any advice!
- Mike
- Mike
