L 3010 kubota
rayj
l3010 hst
Nov 13, 2013
godwin nc usa
My front end loader works very slow and only when the engine is over 2000 rpms I have changed all the filters and it didnt do any good..Is there a strainer that needs to be cleaned and if so where is it located
Bob22r
M7950
Sep 16, 2013
Do auxiliary port in rear work fine? Sound like a dead pump to me or its pulling air? Have you checked all the suction hose?
rayj
l3010 hst
Nov 13, 2013
godwin nc usa
the kubota people say that the same pump runs the power steering and 3 point lift,,they both work fine,,my suction hoses are steel so they cant collaspe ,,thanks for the reply
8,762
It's possible that you have a bad or plugged quick connector, or possibly a bad or plugged spool valve.
Another possible cause would be a bad or malfunctioning diverter valve.
rayj
l3010 hst
Nov 13, 2013
godwin nc usa
i checked the connectors..they seem to be fine,how do i check a spool valve and where
is the diverter valve
8,762
Have you changed fluid or filters mainly hydraulic?
Did it just gradually get slower?
Are the tractors new to you or have you had them a while?
Is it slow in every direction or just one?
Did it get slower the colder it got?
rayj
l3010 hst
Nov 13, 2013
godwin nc usa
yes i changed both filters and fluid,,the tractor has 750 hours on it,,it just slowly got worse,,the rear lift and the power steering works good,,the tilt works pretty good but it is getting worse,,,the bucket lift will only work if it is reving over 2000 rpm and then very slowly
BAP
Dec 31, 2012
2,936
1,047
the tempature has nothing to do with the operation
Those of us that have sub-zero temps will tell temperature can play a huge part in operation of hydraulics. At 90 degrees you can move your loader up and down in about 2-3 seconds. At 20-30 below zero you are lucky to move your loader up and down in 30-45 seconds, if it moves at all. Also, if there is any kind of restriction that has developed, it will get worse with colder thicker oil, that includes ice developing from condensation in the oil.
8,762
BAP nailed it! Temp makes a world of difference to performance.
What brand of filter did you use?
What brand and type of hydraulic fluid did you use?
Horseshoezach
Kubota L3010
Sep 20, 2013
17
Martinsburg wv
well found the problem with my the control valve for the loader was only half on. used a screw driver and turned it the rest of the way on and it works like new now. i kinda feel dumb now haha
8,762
Good to here Horseshoezach, well the getting fixed part, not the feeling dumb part!:p:D
Maybe rayj has the same issue??
