KX91-3S stuck in high range
Sharpe5097
KX91-3s, L4240, Kubota 323 zero turn mower, RTV 900
May 9, 2014
Richville,NY
My excavator is stuck in high range and when i pish the button on the dozer blade control. I get a double beep but nothing happens. Is this a solenoid issue or do i need to take it in and have it looked at.
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,434
78
Rocky Face, Georgia
If you know which solenoid it is you might try unplugging it and plug it back up. My fuel stop quit working on my M9000 and that's what my dealer said to try first. He said it only takes a tiny piece of trash to cause it to stop working. I tried it on mine and haven't had a problem since. Maybe you'll get lucky.
rentthis
1,010
25
summerville,sc
Pull the floor panels and check for mud. I have had similar problems with dirt getting packed under floor panels and getting wet. The moisture gets into the stab lock connectors and causes problems. Unplug and dry all the connectors you can find.. You get a beep so we know that the switch is getting and passing power. That doesn't necessarily eliminate the switch as the problem. I have had to replace those switches before but I don't recall the symptoms. I have a KX-41 with that problem now. I need to get off of my behind and check it out. This is all worth doing because that mud can cause all kinds if phantom problems.
