Was loading some stuff yesterday and engine started to lug like it was running out of fuel. I checked gauge and it showed 1/4 tank roughly. Went ahead and killed it and poured in 5 gallons of fuel. Cranked it up and it was still rough. So I figured fuel pump was going out, which I had a spare. Went and got it and nothing. Ran jumpers from battery and both pumps would kick on. Checked voltage to the harness side of plug and had 12v. When I plug pump into harness I get nothing. Did some research last night and read where you can have 12v with a broken down wire and still not have enough current to run the pump. So I went out this morning and ran a jumper from the positive side of pump plug to battery and the ground plugged in to the harness. Pump kicked on. I tried it the opposite way with the ground just to double check and it wouldn't do anything by using the positive side of the harness plug. So I have concluded that the positive wire is broken down somewhere in the harness. What my question is, is where is the relay for the fuel pump? I would like to run a whole new wire if I can just find out where the other end of that wire goes. I surely do appreciate any help.
