coachgeo
So question is...... is there a "built into the fuel system" a nominal air bleeder on Kubota Diesels? For example on older MB car's atop the fuel filter was a place for air to escape (via hollow banjo bolt with check valve). Escaping air that reached the filter was then plumbed back to the tank thru the IP and Injector overflow lines. It would then vent out.
Many mechanics didn't even know that bleed set up was there cause it worked so well... until of course an air leak was so huge that built in mechanism was over powered.
Is there such an animal on older or newer Bota diesels?
