Kubota ZG124E
kmitch512
Cibolo, TX
My zero turn has been running great. Got it out tonight, it started right up, but when I moved the throttle lever to run, it bogged down and died. Will start right back up, but does same thing. Will not stay running. Any ideas, thoughts or suggestions greatly appreciated. TIA.
2,060
I would check the following:
Do you have enough fuel in the tank?
Is the fuel getting to and through the filters to the pump? Crack the inlet line's nut at the pump. Does fuel come out?
Is the fuel getting to the injectors? Crack the inlet line's nut at the injector. Does fuel come out?
Since it ran and died it sounds like a lack of fuel or that water was in the tank and is now in the fuel lines.
rentthis
1,010
25
summerville,sc
First thing to check is fuel filters. If you haven't done so, change both. The symptoms you described point to clogged fuel filters.
