Kubota Vapor Lock?
speak8
Kubota L3301HST, Loader, box blade
Aug 30, 2014
East Texas
I have a Kubota L3301 with 60 hours on it. It has served me pretty well in our brief association until recently. Now, it runs for 3-5 minutes, then stalls. I have bleed air via the bleed valve on top of the filter, and that works- for about another 3-5 minutes. I can repeat this process until the engine is warm, then it will not start up again despite purging the air.
So I believe I have a vapor lock, I just don't know how to properly fix it. Can anyone suggest another diagnosis? Is breaking the nut on the fuel injectors the only was to properly bleed air?
Thanks!
sheepfarmer
Nov 14, 2014
4,438
677
MidMichigan
I confess to being cautious from the git go, but I would recommend that you not mess with the injectors on this tractor while it is still under warranty. The engine related parts should have a 5 yr warranty because of the tier 4 equipment. I think your tractor has high pressure common rail type fuel supply, so you need a parts diagram and WSM to start with if you were going to mess with it.
As far as the real problem, start with something simple like a clogged fuel filter or a clogged vent somewhere. After that take it in to the dealer if that is possible.
10,281
Diesels don't vapor lock!
A vapor lock is when the fuel boils in the line due to excessive heat. ;)
You possibly have a plugged vent on the cap, tank, or return fuel system.
It's under warranty, take it to the dealer and have it fixed!
And while your there order a WSM, it will answer a lot of questions in detail on proper service and repair in the future.
nzzshl
1982 Yanmar GT14(YM146), 2015 BX25, BX5450 snowblower
Jan 12, 2015
85
Fenton, Mi
I agree with Wolfman on all points. I am most suspicious of a tank vent source being plugged.......the vent has to enable two way air flow. In to compensate for fuel consumption, out to relieve captive pressure during thermal fuel expansion.
