Kubota stopped moving while I was mowing?
ddd
godfrey illinois
Kubota stopped moving while I was mowing? (won't move either fwd or reverse) It's a L3800 with hydro trans.
I heard a "Clunk' and now it won't go forward or backward in 2wd or 4wd?
Thanks for any help!
Tornado
793
252
usa
obvious things first, cause it happens to all of us.........sure its not in neutral?
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
1,837
925
Near Lancaster, PA, USA
OK, I'll admit to a real embarrassment. Years ago I split the Ford 1210 to check / replace the clutch. Upon getting things apart, everything looked fine. After a shower, I went back to look at things again and noticed it was in neutral.
4,242
OK, I'll admit to a real embarrassment..
You know what chim, if anyone says they haven’t done something like that is lying, or never does this kind of stuff.
I tore a chipper all apart because of no spark with a Tecumseh engine.
Worked better after I cleaned everything up, reassembled, and flipped the switch to “on”....[emoji15]
Hopefully there’s an easy solution for the OP.
