Kubota M5700 low compression after rebuild
Chays
Brandon,ms
Just did complete rebuild on my 5 cylinder f2803 new sleeves ,pistons,
Complete valve job on head,cranks and runs but not good and
Only has 175lbs compression.my mechanic says I should be around
500 lbs compression give or take.he has taken injection pump and injectors
And had them check all good.trator only has 530 hours on it.
This is the indirect injection engine also.
Any suggestions would be great at this points?
200mph
Mar 3, 2017
1,228
61
PA
Did all 5 cylinders read 175 psi? Please list the individual readings.
Have you considered a leakdown test to verify where the leak is coming from - rings, valves, etc?
With only 530 hours why was a complete rebuild needed?
8,728
How is it for blow by?
Was a kubota head gasket used or aftermarket one?
Was any milling work done to the head or the block?
Does it run at all?
And yes exact numbers on which cylinders would be very helpful.
Chays
Brandon,ms
from - rings, valves, etc?would have to guy working on it
Had crazy blow by.number5 cylinder rings were gone block was worn bad.
Motor has never had a drop of dirt in it and change oil and all filters ever 100 hours nit sure what happen.
200mph
Mar 3, 2017
1,228
61
PA
It sounds like these are the results of the original motor.
Curious if you did a leakdown test on the rebuild (with low compression) and what the results were.
What are the compression readings for each cylinder?
8,728
Yea I mean blow by after the rebuild... and does it even start now?
2,043
... on head,cranks and runs but not good and...Only has 175lbs compression.
In the original post he said it would crank and run, but with only 175 psi compression I am not sure that is possible if all cylinders are that low...
What do the experts think about it running with all cylinders at 175 psi?
8,728
Yea that's why I wanted some clarity, as it shouldn't start or run if it only has 175 PSI!
