Kubota loaders
Bansheetaz
M4800su
Dec 10, 2018
Crawfordsville
Howdy..
I have a m4800su with a la1002 loader that uses the pin style quick attach for the bucket and hay spear.. my question is if an 1162 or 1251 loader with the pin style quick attach will work with my attachments from the 1002 loader. Thank you for the advice.
3,019
why do you wish to switch?
FEL damaged? Or need more lift?
Or thinking of switching tractors?
Bansheetaz
M4800su
Dec 10, 2018
Crawfordsville
Not going to switch... going to add a larger loader tractor and I already have forks, hay spear, and bucket for the 1002. And if they will work with the larger loaders then I'm good to go
Jchonline
600
Red Feather Lakes, CO
So we understand, you are purchasing a second tractor that will have the LA1162 or LA1251 and you are wondering if those pins will line up with the front implements (bucket, etc) you have for the LA1002.
Bansheetaz
M4800su
Dec 10, 2018
Crawfordsville
Yep that's it. From pictures I have seen of all loaders involved it looks like they should all fit the same attachments. They appear to be from the same era (mid 2000s). They hook over the top of the front bracket and then a large pin through both sides. M8200s and m9000s come with the bigger loaders than the la1002.
Thanks for any knowledge you can bestow upon me
Tx Jim
M7040 HDC & JD 4255
Apr 30, 2013
1,285
181
Coyote Flats,Texas
Due to the fact that each loader has a different part number for a 72'' bucket then my guess is the attachments won't interchange but I've guessed wrong before
