Good evening all, I need some help please.
I started my engine (V2203) about a year ago, the process was simple. I energized the Stop solenoid by putting the two wires onto positive. Then power the starter and it took. (Engine was already out of the tractor) The motor was subsequently sent in to a engineering shop to rebuild.
Over the last two months I put the tractor together again, new clutch and some mechanical repairs. I did not touch the engine, as the engineer put that together. Today I was ready to start the motor. For the life of me it did not want to take. I disconnected the Stop solenoid, loosened the injector pipe retaining nuts and bled the fuel lines (Running the starter for short bursts). Then tied the nuts up, connected the Stop solenoid and tried again "nothing". Then I disconnected the Stop solenoid again and for some reason turned the key, the engine fired up and ran at idle for about 5 minutes, Then the revs picked up and there was no stopping it.
I blocked the air cleaner with rags after a few minutes the revs came down but the engine did not quit, I closed the fuel at the filter. When the filter ran dry, the motor quit.
Now my questions:
1) How does the fuel shutoff (Stop solenoid) work?
2) In my case the Solenoid was disconnected, why did I get fuel? What do I need to check?
3)The solenoid does work, if there is power to it it retracts the pin (Shaft) on removal of power it extends the pin.
4) The solenoid acts as if it is the wrong way around. (Not possible?)
5) What caused the runaway? (Exhaust fumes re-ingested via the air cleaner?)
6) Can the injector pump cause a runaway? (Timing/Set to rich?)
Also the shutoff lever, when is that shut? I assume when I pull it back towards the back of the tractor, not in its normal position. (It made no difference when the engine was out of control.
Sorry but I'm stumped.
Regards Thys
Now my questions:
Regards Thys
