Hello Stubbyie, thank you for your response.
Yes, the machine cranks up well.
It is kept under a roof, not in a shed.
Block heater not in use yet, as it starts up right away.
The past two days we started the tractor at -6C, about 22F I think. The Glow Plug Indicator momentarily flashed on, on the IntelliPanel and then, off.
The salesman phoned at the end of last week and again today so we feel happy about that, and not abandoned as we had before.
I ordered a copy of the Shop Manual. Since that takes a while to order he is printing one up for us and sending it.
Last week he told us to check the fuse and if not 'broken' means it is OK. If not that, it could be a wire.
Today he said when someone comes out this way they will stop and look at it. We are 100 miles from them, over a high mountain range. I told him the indicator showed the past two days.
When we bought it, in October, it arrived on the 20th, the Glow Plug Indicator lit up when the key was turned. The temperature then was warmish, shirt weather. The next three or four start-ups, it also flashed on, enough to be noticed. Since then, until a couple of days ago, no-show.
My husband wondered if he had pressed something by mistake in getting in to the tractor, ie the control panel and this caused the problem.
He has poured through the Owners Manual, looks at it every day, but can't find anything which addresses the Glow Plug indicator.
He also can't find how to reset the IntelliPanel to Default. This I imagine will be known to us when the Shop Manual arrives.
I have printed out all the information you and others gave us on here, a copy each for which we are very grateful.
I shall come back here when I have any new information from the manual in case someone else needs to know.
Sheep Farmer, the flash of the Glow Plug Indication is like greased lightening, blink and you miss it, so far that is, at -6C, 22F.
We would be interested to know how you make out with yours in colder weather.
We started with the same Ford 8N as you, then to a Massey Ferguson 230 so we too, are making an enormous jump in technology.
Thanks again. You were like a raft when we felt we were drowning.
Jennifer
