Kubota L3010 - Remove front tire?
phillyd2
Bucks County, PA
One of the front tire has a slow leak so I need to remove to have it fixed. Never having done this, whats the best way? I'm thinking - loosen all nuts, use bucket to raise front end, slide in a couple of jack stands, remove wheel from tractor.
Does this sound ok?
bosshogg
2004 L3400F w/ FEL
Aug 16, 2012
231
Hartford, SD, USA
Does this sound ok?
Get a small tube that just fits over the valve stem. Take the core out of the valve stem and dump some a pint of liquid starch into the tire. Re-install core and fill with air. Drive it around a bit. Search Liquid starch tire repair for more info.
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,440
73
Rocky Face, Georgia
Go to local TSC or most anywhere now days and get you a bottle or jug or Slime. Unless the hole is big enough to throw a cat thru the Slime will seal it up. I sealed a hole in a tire last year that had a stick in it about the size of my little finger. There's lots of different ways to fix a flat tire but it doesn't get much easier than Slime.
