Kubota L2900 series
calvery
17
Whitwell, TN
I recently left my tractor out in the rain on accident when I moved it into the shed and turned the key off it didn't turn off. It kept running, so I cut off the fuel to get it to die and turned the key off. When I did the key starting buzzing for about 3 seconds and then went off. I'm guessing that I have a stuck relay or something. Any ideas? Thanks
8,731
These tractors normally don't care about getting wet, I think it's just an unlucky coincidence that your problems started after it got wet.
Sounds like a problem with the stop solenoid or relay for the stop solenoid.
Get the WSM and it will give you the steps to repair it.
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,434
76
Rocky Face, Georgia
My M9000 failed to shut off with the key after I washed it. It has done this 2x in the last year or so. I talked to my dealer and they to me to unplug the wire that goes in the fuel shut off. Said to make sure it was dry and clean because just a small spec of trash could cause this. I did what they said and made sure it was clean which to be honest I didn't see anything. Haven't had any problem with it since.
