Kubota L2850
gastank727
l2850
Dec 9, 2013
14
ME
Ibought new aggs and rims. front are 7.2x16 rear are 12.4 x24. will they work? book calls for 7.00x16 front
9,723
You will need to check the RC #, if it's too large you can do damage to the front drive components.
tiredguy
B3030 HSTC,B2781 51" front mounted snowblower,60" MMM
Jan 21, 2010
301
northern lower Michigan
Shouldn't be a problem as the difference in the size is going from 7-16 to
7.2-16 which is only 2/10ths of an inch in width only. If memory serves me correctly only Goodyear and Titan build/built the 7.2's everything else is 7.0
To be absolutely certain compare the rolling circumference of the old tires versus the new tires looking at each manufacter's data specs on the tires.
As long as you're within 2% you're good to go.
Al
