Kubota L235 no start.
MTf6157
Kubota L235
Dec 26, 2025
10
Butler county pa
Pulled intake manifold off and replaced the glow plugs. Installed new manifold gasket but now the engine just cranks like if I pull the compression release. No smoke. Tried bleeding the lines still nothing. Now I noticed fuel around the bottom of one of the nuts coming out of the pump. Any ideas? I thank you in advance. Mick
3,191
I would just assume it is a fuel issue but also check that the glow plugs are tight enough. So if you can torque the glow plugs without taking it apart again, I would check them.
Then starting at the pump, hold the larger nut below the fuel line and then tighten the fuel line nut to stop the leaks. Then bleed the fuel system starting with the bleeder screw at the pump. If you don’t know how, just ask and we can give you more steps.
MTf6157
Kubota L235
Dec 26, 2025
10
Butler county pa
Thanks Russell. I loosened up the bottom nut on top of the injector pump, that's the one that was leaking because I thought I over tightened it. That no longer leaks. My question is did I disrupt the pump timing and would that cause the engine to turn over like I had the compression release open all the way. Glow plugs work great after replacing the ignition switch. Thank you
11,493
No that has no effect on timing and has nothing to do with the valves staying open.
Did you get good bubble free fuel to the injectors when you bled them?
MTf6157
Kubota L235
Dec 26, 2025
10
Butler county pa
Steady stream from pump bleeder but much less from the lines at the top of the pump. Closed them off and opened the top lines and very little came out. Engine still just spins with no smoke. Don't know what I did just removing the intake manifold and replacing the injectors. Thank you.
3,102
How long did you crank to allow the diesel to come through each injector line?
You open all three at once? OR each one separately?
3,191
Are you saying it spins fast (like you are using the decompression knob) or it just doesn’t fire off at all?
11,493
Let's keep one issue in the same thread:
Where did you get the injectors from?
Did you put new sealing washers on the injectors?
3,191
Now I am getting confused…
Did you replace the glow plugs (as you stated in post #1) or the injectors?
Please confirm what was replaced and where the parts were acquired (OEM, brand, …).
To provide some information to your questions…
1) I think that turning the lower large nut is a bad thing and may change fuel delivery. But I also think your tractor should still start and run (poorly?) on two cylinders. @North Idaho Wolfman can confirm if this is correct.
2). The amount of fuel out of the pump (per line to injectors) is more than the injectors actually use. There should be black hoses that connect from the front cylinder to the second cylinder to the third cylinder and then dump back into the tank.
Now some trouble shooting ideas since it is spinning and not firing off.
A) Test the glow plus to see if they are actually working. I assume your ambient temperature has gotten lower recently and my similar L185F won’t start easily even in 100 degree ambient. You can see if they are getting about 10 to 12 volts to the bar that connects them together when the rocker switch is in glow position and also in the start position.
B) Try bleeding it more with the throttle set to full throttle and using the decompression knob so the starter can spin the engine at a good speed. You can assume you are good when you don’t see any air bubbles coming out of the lines. I focus on the front injector then close it and then focus on the second injector and close it. If the tractor starts then I crack each injector one at a time and let a bit more fuel out and see if that cylinder stops firing off.
C) If you didn’t replace the copper crush washers under the injectors you may need to get new ones and unfortunately replace them since they could e leaking compression. You may be able to test that with some soapy water at the base of of the injectors. If you used some injectors off the internet, not OEM, then replace the injectors with OEM injectors or have your only ones rebuilt.
C) Test the glow plugs for leaking also.
D) Provide 12 volts from battery positive to the bar on top of the glow plugs for approximately 15 seconds and then remove it and quickly see if the engine will fire off at all. That will show if you are fighting a glow plug problem or something else.
