Kubota ECM wiring Diagram needed
Kubota Tuner
9
I'm looking for an ecm wiring diagram. The ecm is off of a SVL90-2. But is used on other machines as well. Denso Ecm. Part # 1J520-59051, hardware # 275700-1201. I'm trying to build a bench harness. So basically looking for battery power, battery ground, ignition and Can + and Can - . Any help would be appreciated.
Thanks!
Kubota Tuner
9
Anyone at all have access to these ecu schematics? Someone must have dealer access...
Serial # V3800-T-2CN4015
Engine code# 1J542-16000
Engine Model# V3800-CR-TE4-L6
Any help would greatly be appreciated.
Thank you!
Kubota Tuner
9
Sadly no the WSM does not have the schematic for the ECM in it.
Thanks for the responses guys. I managed to get some diagrams. Unfortunately they were pictures of large printouts and they are barely legible. Or else I would post them for everyone. But I did manage to get the pins I need. They may help someone, somewhere...
Connector B
B+ pin 5
B- Pin 1
Can - pin 52
Can + pin 51
Ign pin 47
Tested and it connects..
Thanks!
