kubota d782 compression
thomas57
kubota motor d782 3cyl mower
Apr 20, 2021
florida
I got a used kubota mower with kuboda eng d782 compression is low 270 lb on all 3 cyl . after I put a little oil in each cyl it will go to 400 psi . are the rings bad or just stuck ? it only has about 1037 hours on the mower ,, but was sitting for a wile ( do not know long ) the oil that came out of it was like tar , it took 2 oil change to get oll out .
hagrid
K1600GTL, ZX-14R
Jun 11, 2018
991
1,337
Pittsburgh
Will it run? After 30 minutes at idle stuck rings might unstick. After that, if it's still down on compression I'd remove the head and check the bores for damage. If they're good you might consider a rebuild.
2,828
I take it the glow plugs are still out .....
place about 2 ounces of marvel mystery oil in each cylinder ........ let it sit ........
do it again the next day ....... and once more.
Then run another compression test ....... if it improves, they were stuck - if not, then time for rebuild.
thomas57
Apr 20, 2021
florida
yes it did run but ruff so I shut it off ,, both before and after oil change ,, got 3 new inj but did not put in yet
