Kubota D750-A Engine
Stubbie
B7100HST
Apr 17, 2025
Would someone be able to identify the head bolt size (mm & thread pitch, etc.). I used the thread identifier at the local hardware store and neither the SAE or the Metric appeared to be a perfect match. The threads on the existing bolts are in good shape. Thank you.
2,737
if the net is correct:
bolts are M10 x 1.25 pitch
Stubbie
B7100HST
Apr 17, 2025
Thank you. The M10 x 1.25 pitch on the thread identifier was the only one it would thread into but was sloppy loose.
Thanks again.
Stubbie
8,266
Do you need head bolts?
