Kubota BX2370 block heaters going open
BX'r
BX2370
Jun 13, 2020
115
26
Sault Ste. Marie, Ontario, Canada
There is a problem with these as they go open after a very short time.
Maybe the water drops below the heater a little and they burn out.
You might want to check yours if it's older than two years.
Time for an oil immersion heater.
3,061
Bx'r
Was this a reply to a post? Seems to have gotten lost in cyberspace!
As for the oil heater - better than nothing obviously but it will not heat an engine as fast or thoroughly as a water jacket or inline lower radiator hose.
BX'r
BX2370
Jun 13, 2020
115
26
Bx'r
It was more of a "test your block heater" the life span of these seems to be two years (two seasons).
I have to wonder how many people are plugging in dead heaters?
Why they quit is a mystery, the only reason I can think of is they aren't totally covered in water.
I have been looking for a heater for the lower hose which I think is 3/4 inch inside but a 1 inch heater fitting might work.
BX23S-1
565
225
No where Special
I`ve never used them just for that reason alone. I hear people complain about them because they dont last long. Any that i`ve seen, are of cheap quality from what i`ve seen. Pretty sad for what they cost you.
I have a big heater i can park near my tractor to warm it up if i have to. I havent needed to in awhile though.
whitetiger
Nov 20, 2011
3,707
2,130
Kansas City, KS
How long do you leave it plugged in for?
BX'r
BX2370
Jun 13, 2020
115
26
It's not the cord, this is a common problem with these heaters.
I only used these heaters for one hour to one and half hours. at a time.
Thus the reason for installing an ammeter, I was suspicious after the first one failed so quickly.
whitetiger
Nov 20, 2011
3,707
2,130
Kansas City, KS
We install a lot of the heaters and rarely ever see a failed element. Most of our customers only run the heaters for under 2 hours.
