Kubota BX 25 Bucket hooks, are these any good ? which style?
3,251
In over 20 yearsI’ve never felt the need for a D ring on the bucket.
I would go with the grab hooks only, as shown in the second link.
There’s a thread here somewhere titled something like "show us your bucket hooks” you might do a search for. It would give you a lot of examples of what people here find useful.
Edit: This one:
yorkies77
Kubota BX23S
Jun 7, 2020
80
62
Idaho
I got mine from bxexpanded, no welding and you can adjust them yourself for each time you use them. Took me one minute to install them. Absolutely love them.
Joe.G
BX25 W/601
Oct 13, 2024
74
19
NY
www.boltonhooks.com
Bolt-On Hooks - BoltOnHooks LLC
Bolt-On Hooks and other accessories for compact tractors.
www.boltonhooks.com
www.boltonhooks.com
www.boltonhooks.com
Bolt-On Grab Hook™ with Hardware - BoltOnHooks LLC
Bolt on hooks. Bolt on tractor hooks, Bolt on bucket hooks. Bolt on loader hooks.
www.boltonhooks.com
www.boltonhooks.com
www.boltonhooks.com
1/2″ Bolt On D-Ring - BoltOnHooks LLC
4,000lb *WLL Zinc Plated May be Welded *Bolts NOT included* Imported
www.boltonhooks.com
www.boltonhooks.com
www.boltonhooks.com
Bolt-On Clevis Mount™ without Hardware - BoltOnHooks LLC
Clevis mount, pad eye.
www.boltonhooks.com
www.boltonhooks.com
www.boltonhooks.com
Grab Hook/Clevis Combo - BoltOnHooks LLC
www.boltonhooks.com
www.boltonhooks.com
www.boltonhooks.com
1/2" USA Made Screw Pin Shackle - BoltOnHooks LLC
CM Shackle
www.boltonhooks.com
www.boltonhooks.com
3,251
Did a new member just spam the the thread with an advertisement?
Did we get sucked into answering his original question?
Edit: not implying the products shows are not quality items from the looks of them. And I want to think Boltonhooks may be a paid member here as well. Curious...
Joe.G
BX25 W/601
Oct 13, 2024
74
19
NY
I am not spamming These are from my post on Tractor by net that someone had shown me.
WAS BANNED FOR NSFW PICS
5,155
He just gave you the opportunity to make another post. What are you now averaging 6 or 8 a day?
Mark_BX25D
Bx25D
Jul 19, 2020
1,881
1,365
It would have been a good idea to explain that with your pictoors. We just had a
"new member spammer" incident, and I guess maybe we are a bit touchy.
(y)
On another note, I'm with Henro on the D rings. I think they will be in the way with that setup.
Unless you expect a regular need to use ropes, I would stick with the grab hooks. If you really think you need the D rings, I'd put them a few inches away from the grab hooks.
Joe.G
BX25 W/601
Oct 13, 2024
74
19
NY
I am confused? If this is pointed towards me I am not trying to spam, I am just a new owner with a questions.
I have things that I want to do to make it mind/set up for me and trying to learn from people that know.
Joe.G
BX25 W/601
Oct 13, 2024
74
19
NY
I know the hooks would be more useful, Just wasn't sure if I was missing something with the D rings. Figured Id ask because I only want to drill holes once.
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
2,767
2,139
Near Lancaster, PA, USA
If you aren't into fabricating go with Ken's. My BIL (also a "Ken") has some of Ken's BOH's and they are top notch. I would recommend Ken's products to anyone who wants something that is made well and looks good.
Joe.G
BX25 W/601
Oct 13, 2024
74
19
NY
I looked at some other ones on Kens site and they seem like they would fit teh particular buck I have better then some in the links.
Kens just came highly recommend from another site I was reading, I think I will just go with the bolt on hook, I may weld one on to the Backhoe bucket as well.
BXHoosier
BX24
Jan 21, 2018
497
591
Indiana
I went the cheap route and bolted on some weld-on hooks to the sides of the bucket with 3/8” bolts.
3,251
Interesting! First time I’ve seen that done!
Certainly thinking outside the box!
I suppose you could hang a bit of excess chain over the bucket top lip, and that would keep the chain in the hook until you got it under tension.
5,795
Ideally install 'inline' with the loader arms 'for best results'.
Might consider a thick flat bar or angle iron 'stiffener' on the inside of the bucket to prevent top lip from curling down.
Trimley
BX23SLSB-R-1 plus additions
Jul 25, 2023
1,181
872
PNW-WA
I like my hooks welded on a 2"×3" - 3"×3" plate, then the plate welded inline with the loader arms. *The more surface contact the better.*
jyoutz
Jan 14, 2019
3,430
2,518
Edgewood, New Mexico
Hooks inline with the lift arms are best. For center lifting, drape a chain on both hooks and connect in the middle to center the chain.
Bearcatrp
Mar 28, 2023
972
617
Minnesota
Just catching up here, I have also responded on TBN.
Looks like you need our 1-5/8" spacered hooks, the ones in the "pin-on" section of the website I linked earlier. There are also measuring instructions on that page.
These look good. Will have to see if they will work for my 1880.
