kubota b7100 gear to hydrostatic
danmorea
kubota b7100 loader/backhoe Kubota B2650 loader John Deere x540
Oct 25, 2013
95
15
narrowsburg ny
Have a 1979 b7100 with loader b219 and backhoe b670 that is gear drive I wonder i buy a newer hydrostatic b7100 if my loader and backhoe will fit
8,829
Yes should hook right up, the frames are the same.
Rob
B6000DT / B7100DP /B8200DT/L225/Globe PTO Chipper/Lewis Backhoe/huxley TR66
Nov 22, 2009
679
11
Leafy England....
hang fire before you rushout a buy a hst 7100, they are not the same dimensions as the manual 7100 version.
the drive shaft tunnel is wider than the manual version, also the the overall lenght is more so you'll need to ensure that the loader subframe will fit the mounting points on the hst and thus the backhoe then fits onto the loader frame at the furthest point onto the loader subframe.
i had a hst and tried fitting a loader from my manual and had a heap of issues, gave up in the end, if in doubt check first , its allways best with these sort of fittments.
you'll prob be fine , but thought you should be aware that just becuase its a b7100hst its not identical as the manual version, quite a few differences to be honest.
good luck.
3,099
I have no personal knowledge of this, but I've been told the HST is longer. You might have issues with the B670 subframe rails being too short.
hodge
Nov 19, 2010
2,950
514
Love, VA
It is safe to assume that the two versions have different dimensions, and warrant checking into before dropping the money.
Rob
Nov 22, 2009
679
11
Leafy England....
its the hst gearbox that accounts for the extra lenght, and we are not talking a few mm either. this will be the biggest issue as your loader side rails will not be long enough to reach the rear axle mounting points in the same way as on your current manual 7100, also becuase the drive shaft tunnel assembly is wider to accommadate the hst pump etc and the associated directional linkages, you may find the subframe mounting plates are not positioned wide enough to mount to the tunnel sides, unless they are adjustable but most are welded to the cross member and would need cutting off and refitting to suit the wider hst tunnel.
best advice would be to a tape measure out and compare dimensions.
rob
8,829
So I stand corrected I thought they were the same.:eek:
I ran the #'s that you gave for the loader and back hoe, Those #'s don't match up to the newer B7100, so they may not work.:(
The Newer B7100HST-D takes Loader #B1630C, and Backhoe #B4672
danmorea
Oct 25, 2013
95
15
narrowsburg ny
rob
I will run into problems for older hydro from 1980s newer 1990s or all years? For my work i have to change gears a lot -it makes me tired
Big Kahuna
Kubota 2000 L3010 HST with Loader ,1992 B7100HST , 1979 B6100E & 2007 F2880
Dec 23, 2011
369
9
Homer City, Pa.
Yes, a B219 loader will fit a HST 7100 and this was the first loader they used on them, they had frame extentions to get to the rear end mounting, about 6 inches, thats about the length difference from gear to hydro, I personally have done this, IT BOLTS RIGHT ON. They are the same width on the frame, just the hydro is longer by 6 inches, I feel the back hoe would go right on also, if the brackets go past the rear end then you'll need to make extensions.
Big Kahuna
Rob
Nov 22, 2009
679
11
Leafy England....
Big K , is there any chance your loader is a revised version, i had a bog standard unmodified 219 and there was no way it fitted my hst, fine on my manual 7100, but no go on the hst.
possibly a revision somehwere in subframe fabriactions .
rob
Big Kahuna
Dec 23, 2011
369
9
Homer City, Pa.
When I blasted the cylinders, date codes were October 1979 on 3 and 1 January 1980, the tractor was a 1982 model. ? The donor tractor was a 1980 B7100 HST, went right off and right on.
Big Kahuna
