Kubota B5100DT 3 point hitch falling
BonnySlope
BX2380FEL, Add-A-Grapple, Titan 48" Box scraper, 60" Rake, 72" Rear Blade, Flail
Apr 11, 2021
130
105
NW Oregon
I'm aware this has been covered but not able to locate for my case....tractor :)
Well I got a new tool for my little orange work hand (B5100DT) I attached the box scraper to the tractor and did my 3 pt. linkage adjust raised RPM's to just under max (3000 just under full) and lifted without issues but immediately began to lower. Didn't see any leaks in trans/hyd. lines. I decided to check this I took for granted like interlock rod lockers. Made sure locker B was up against factory stop on rod (drivers end)and then measured out to the A locker end and had to adjust in to the suggested 4.88 setting ended up narrowing about .31. Second attempt it lowered a little slower but still had to keep an eye on with continued lifting. Before when I checked the interlock rod I slid a go/no go shim to the implement lowering speed nut and it was fine. New territory here for me is I believe I read that closing nut completely and if lift held when closed would indicate your piston O ring was fine. What I'm going to do is work in quarter turns... Ok I will try closing it to see if it will hold.
Wouldn't mine taking a look at the piston and cylinder wall and replace the O rings or ring. With the drawing I see they really don't show a good stacking order they show two, is one a whipper with the Back up Ring in the piston groove? and the other a closure O ring. using Messicks and I&T and Kubota Service manual.
3,340
Not having that model tractor I’m not familiar with what you are describing as “locker A” or “B”, but....
When you say it is immediately lowering.... the tractor STILL IS RUNNING.... right?
The 3-pt will drift down at a speed commensurate with the condition of the cylinder and the let-down-knob under the seat when the tractor shuts down
Chesapeake
B6100
Apr 1, 2021
27
10
Washington
My b6100 had that issue of the 3pt slowly lowering. Oil leaking past the piston o-ring.
Old set up was an O-ring. Mine was very worn.
New setup was a thin spiral ring of white PTFE or UHMW and then the O-ring. Not sure if the plastic ring is a whisper, or just to take up space and make the O-ring fit better.
After replacement mine will hold my tiller up for hours now. Before it wouldn’t hold it up for 5 minutes.
Pretty easy change out. Just look for tutorials for B7100 if you can’t find one for a 5100. Should be very similar.
8,304
That model does not have a "let-down-knob" ( Drop speed adjustment ) under the seat.
It has a drop speed bolt on top of the controller.
8,304
The white ring is back up ring.
It's job is to allow the O-ring to slide when hydraulic pressure is released.
8,304
Does the control for the three point snap back to center when it reaches max height?
Does the control snap back to center when it reaches max lowering?
Will the three point without any weight on it stay up at any height?
BonnySlope
Apr 11, 2021
130
105
NW Oregon
Thanks Chesapeake, I did find a pictorial of some ones O ring replacement on a B7100. They just replaced piston O ring no wiper ring(UHMW or Poly) backing up O ring or cover O ring. I saw on Messick's they don't even list a cover O ring. On my tractor my covers not leaking. Other materials could be used to seal metal to metal surfaces.
Thanks again for finger point. Let me get on the phone and see if I can find local.
BonnySlope
Apr 11, 2021
130
105
NW Oregon
Hey NI Wolfman (no offence to shorten name) Thanks for input.
Does the control for the three point snap back to center when it reaches max height? yes
Does the control snap back to center when it reaches max lowering? yes
Will the three point without any weight on it stay up at any height? yes it does! Ok a very slow by pass but I have my safety chain on.
The spring has been spray lubed. I'll go through your questions again and monitor. My current response is what I recall... yes need to refresh what I recall.
8,304
No offence taken, NIW is what most use.
Or some other things I can't repeat! :ROFLMAO:
With what you said is happening pull the front cover and look fort pitting in the sleeve, if it's not pitted get a new O-ring and back up ring and You should be able to fix it.
If it is pitted or scored badly get a sleeve and maybe even a new piston.
Get a gasket or O-ring for the cover too.
BonnySlope
Apr 11, 2021
130
105
NW Oregon
Well I found O ring and backup ring(wiper) 11 miles (local) normally stocked, Back up due in on Thur. Have to make decision to prep now and use tractor to haul trailer and wait for tare down the day before. If we all could have such tuff choices this past year. :rolleyes:
Cheers, thanks again will post revel.
BonnySlope
Apr 11, 2021
130
105
NW Oregon
The cover/cap o-ring looks to be 04810-50550.
You’ll also want the little O-ring for the valve port 04811-00100.
Thanks for the numbers Chesapeake. I was lucky local dealer/supplier (11miles) has everything on shelf except Backer ring which will be in on Friday. I have enough property task to keep me busy until then
BonnySlope
Apr 11, 2021
130
105
NW Oregon
Well I got it done and test lifts box scraper just fine. It's tight with nothing on 3 point I have to assist to lower arms.? May need a little adjust?
Bore measured 2.379 (factory is 2.36 with plus and minus) and the old O'ring was cone shaped. It would be interesting to see a new piston, it's like they only machine the O'ring grove and very light else where.
Need to put my weighted ag tires back on rear. My turf tires a slow leak in one and even with a tube they need to come off.
Chesapeak the value o'ring you suggest(parts C) and I checked Messicks and got a updated number it was only 88 cent but I was still trying not to have extra parts. I was able to match up from my O'ring inventory HF assorted box. Over all thirteen dollar and change for the fix.:D cool.
Thanks again folk for you thought.
Chesapeake
B6100
Apr 1, 2021
27
10
Washington
Good to hear.
Mine also needs assistance to lower the arms when there is no weight. I kind of expect that to go away after the o-ring takes a set and has some wear. It’s no issue to push them down though.
BonnySlope
Apr 11, 2021
130
105
NW Oregon
Here a picture of the piston with new o'ring and
backer ring. Piston looks scared up but wiped down with 200 G wet and dry paper. See how old o'ring is coned
Ragnorok
B7100D
Mar 6, 2025
New Hampshire, USA
I'm doing this exact procedure on my B7100D. I have the top off the cylinder but while the piston slides in/out and rotates easily I can't get it to come out. I searched here for the mentioned B7100 tutorials and found nada, which is becoming distressingly normal. Is there a way to extract the piston without removing the entire block from the frame? That's a lot of work I'd prefer to avoid.
Thanks for your time...
torch
Jun 10, 2016
2,653
890
Muskoka, Ont.
I believe the piston just floats on top of the piston rod and is not actually attached. The manual says to push the piston up from the bottom, but they are showing it with the entire assembly removed.
What happens if you push down on the lift arms? Can you get a little extra motion to pop that piston above the cylinder casting a bit so you can grab it?
Failing that, some sort of suction? Shop-vac and a rag maybe?
8,304
I have 2 strips of thin steel with a very small hook on the end that I can use to pull the pistons out.
Like @torch said the piston is not attached to the rod.
Ragnorok
B7100D
Mar 6, 2025
New Hampshire, USA
After posting I stumbled across a B6100 thread with relevant suggestions, one being use the interia of the decending lift arms pushing the piston up, and one use a magnet to grab the piston and draw it out. Neither worked for me, but *together* they did the trick. Piston popped right out and it's back together now.
Thanks torch & North Idaho Wolfman!
