Kubota B2910 3PT Linkage Question
AC Ridgeline
Kubota B2910
Sep 19, 2026
Pennsylvania
Hello, new here and just purchased my first Kubota, a 2004 B2910 HST. It came with a backhoe attached, which was a plus for buying it, however it did not come with any of the 3 PT linkage. Went to my Kubota dealer and looks like it would cost around 1,500 to 2,000 to get everything I need because I would need to purchase everything individually.
My question is there a good aftermarket setup (I found some that claims they are for a B2910, but look way too small) or a good place to find a used set. I am new to tractors so I am unsure if there is a such thing as "universal linkages" or if you need specific 3 PT linkages designed for specific tractors.
Thanks in advanced for any help / advice / information!
3,155
You may be able to get a complete kit from the dealer sales (not parts) department. Talk to them about a wholegoods kit and see if they are cheaper and available.
11,268
Most of the aftermarket stuff is pretty weak and flimsy.
Send @Mountainman a message and see if he has what you need.
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
3,970
2,463
WestTn/NoMs
If that doesn't work out, there's a B3941 kit available from Kubota. It's made for the B26TLB, which apparently doesn't come with the 3ph parts. It's around $600.
Will it fit, I don't know? You could measure the diameter and approximate spacing of the lower arm attachment at the tractor, and the size and spacing of the lift rod attachment (you do have the rocker shaft arms?). Then, if your nearest dealer has a B26TBL on the lot, compare measurements. If not, someone on this forum with a B26 might measure and post.
Bibi38
Kubota BX23S
Sep 24, 2026
NY
Dealer wants $2k? Ouch. No universal kits, hunt eBay or FB for a used B2910 set. Way cheaper.
