Kubota B21 Backhoe/Loader
10,385
Yea you can't search 3 digit items.
So try "B21 hydraulic issue" as an example.
100 td
Aug 29, 2015
1,776
9
38
ɹǝpunuʍop
Unfortunately you can't!
EDIT: Typo on my part: NIW
Sorry - no matches. Please try some different terms.
The following words are either very common, too long, or too short and were not included in your search : b21, tlb
So if you search for B21 hydraulic issue, you get EVERY post with hydraulic issue in it, which 99% won't be about a B21.
B21 front loader combination backhoe machines are referred to as "TLB" (Tractor Loader Backhoe), not that that makes it any easier to search for as 3 letter combinations do NOT come up as a possible search parameter.
However, the FEL (Front End Loader) is a TL421 and the backhoe is a BT751, and if someone has posted these "specific" numbers when referring to their "B21 implement", then you will bring up results relating to those implements.
Unfortunately not everyone talks about the exact model of their hoe or FEL, just a B21 backhoe or loader, so you can miss a lot of threads.
