installed new hydraulic thumb only works one way.reversed hoses worked the other way.Installed hydraulic thumb.only works one way.
Yes has push button on control panel .push once solid light is for thumb.push twice for hammerIs there an option on that model to change the function from motor driven output to ram output?
Removed hoses one hose has pressure the other does not.can reverse hoses works the thumb the other way . What and where is the valve that controls the thumbs port.Remove both hoses from the cylinder, put them into a bucket, activate the thumb control both directions, if you get fluid out of each hose then the issue is in the ram, if fluid only comes out of one of the hoses, then the issue is in the valve for the thumb.![]()
