Kubota 121-3 kx
8,749
Is there an option on that model to change the function from motor driven output to ram output?
8,749
Remove both hoses from the cylinder, put them into a bucket, activate the thumb control both directions, if you get fluid out of each hose then the issue is in the ram, if fluid only comes out of one of the hoses, then the issue is in the valve for the thumb. ;)
robber50
Choudrant,la
Removed hoses one hose has pressure the other does not.can reverse hoses works the thumb the other way . What and where is the valve that controls the thumbs port.
8,749
The solenoid valve for the thumb to breaker control seams to not be working as it won't switch from breaker control to thumb control, could be a fuse blown, could be a wire disconnected, could be a mechanical issue or a bad part.
I would suggest at this point you need to get the WSM (Work Shop Manual, aka Service manual) for the unit.
It should give you the troubleshooting info for the system.
Serial# 20000->29999 P/N 97899-60551
Seral# 30000-> P/N 97899-61260
robber50
Choudrant,la
Got to have more help.i know someone out there has seen this before.have repair manual takes I don't know what to understand it.everything works on machine but thumb works only one way .is the rocker switch on hand control have voltage on it? If so where does the wires go and what do they operate.
robber50
Choudrant,la
I fixed it on right side of machine under floor is a solenoid valve with two solenoid .removed one was stuck. Thanks for the help but was a lot of looking and trial and error
