Kabota u17 mini excavator keeps getting hot
gary baden
kabota u17 mini excavator
Sep 23, 2024
walla walla washington usa
My u17 mini excavator runs great for 30 to 45 minutes then gradually starts getting hot. Eventually it gets really hot and if I run it too long the small water filler tank is boiling when I turn off the machine. The machine runs great and seems to have good power. Also, there is no discoloration in the exhaust
2,831
Gary,
not being an A$$ but lets start with the company - KuBOTA ...........only ONE "A"
Getting to the heat - have you cleaned the radiator REALLY REALLY well???
Once you get to the blown head gasket and the exhaust color change - it will be WAY too late.
boiling water in the reserve tank is a sign of bad things to happen soon.
GET a good air compressor = blow out the radiator well, then do it again, start from fan side out.
5,682
hopefully it has 'coolant' and NOT 'water' in the rad !
50/50 antifrezze /water.
as SOON as the heat goes up SHUT IT OFF !
maybe a loose fan belt ?
