Hi folks. Appreciate all the info found on this forum. I finally pulled the trigger on a new L4760. Along with the tractor I am getting: LA1055 FEL, 3rd function valve, RCF2072 bush hog, RGC1060 grapple, block heater. I will get the rear tires loaded with Rim Guard.
The tractor will be used on a hilly property in Vermont. Primary uses will be using a grapple to clean up the woods, meadows, orchard, etc..., bush hogging about 10 acres, hauling firewood, etc...
Is there anything else I should consider? Pallet forks? Can anyone provide feedback on the RGC1060 grapple?
I'll look into adding photos.
Thanks!
Thanks!
