jerking 3 pt hitch
mcdee190
21
acworth ga
I have an L 2800 that when you lift the three pt hitch up slowly it jerks the whole tractor. Pull fast and it goes up normally. Pressures are normal @ 2200 psi I think its in the control valve but need some advice.
coachgeo
Nov 16, 2012
2,459
37
Southern OH
do not know if below is also an issue with the L2800 or not
http://www.orangetractortalks.com/forums/showthread.php?t=17412
if you have not done so already do a search of this site on your model tractor to discussions others have had on your model's 3pt
CaveCreekRay
Jul 11, 2014
2,631
105
Cave Creek, AZ
Keep an eye on the thread Coachgeo listed. I will update it as things unfold with my L3800. I am going to visit the dealer today.
Bluegill
Jan 11, 2012
1,559
Success Missouri
The real bad ones can be adjusted internally (top of the valve body has to come off). But the basic L will always have a slightly jerky hitch, only noticed when raised VERY SLOWLY.
8,731
If it just started doing it out of the blue, then something is wrong.
When was the filter and fluid changed last?
What kind and type of fluid and filter used?
