So for the money I took a chance on a tractor that was described as "not running, not seized" from a kubota dealer in Michigan. It's a B6000e, only 2wd but we all gotta start somewhere. I found a guy on uship.com to haul it to Fargo ND for $360. Upon arrival the battery was dead and froze, so I drive a mile to the local wrecking yard and pick up a 10 month old napa battery for $30. Oil needs changing and coolant was low. Installed the battery, preheat and crank. About 60 seconds later it fired up, probably would've started quicker if I knew which way the throttle operated but I figured it out. Topped off the coolant, checked the operations of all the levers trying to figure out what does what. Idk how much the 3 point can lift but I stood on the bars and it lifted my 325#. It does need some tlc. Change the fluids and filters, I did siphon the old fuel out and added fresh along with a couple ounces of seafoam. I am missing the bottom portion of the air filter and it could use a muffler but it's not too loud. Needs rear tires bad, it has 245/75/16 on it now. I'm kinda stoked. Lol
