Issues with a Jacobsen HR 5111 Mower that has a Kubota engine
Batdevice
Jacobsen HR5111
Oct 31, 2024
Yorkton, Saskatchewan, Canada
Hi,
I have a Jacobsen HR 5111 mower that has a V2203-B Kubota engine. The problem is that the mower does not charge properly with the volts varying from discharge to some charge (8 volts, etc) The mower will run when the battery is fully charged until it runs down. I have replace the alternator, battery, start switch to no avail. If I remove the negative post on the running engine the alternator charges a constant 13.5 + volts. Any ideas on what could be wrong would be greatly appreciated. Very frustrating problem.
rudder35
MX4800, G1800, Bobcat E26
May 22, 2023
35
ac3510!??
Hi,
Clean the ground strap connection on the engine or chassis.
