Install Hydraulic Remotes on 3901 HST?
Greg5278
Kubota 3901 HST
Feb 9, 2017
Lambertville, NJ
I am looking to run a 3 Point Hydraulic Log Splitter on my 3901 HST.
My Question is where is the easiest way to connect the Lines for the Splitter?
My Thought was the Quick connects on FEL.
The Splitter is a Wallenstein 310X. IS there a way to add in some Remote Lines under the HST Pedals?
Thanks for the Help.
Greg 5278
BAP
Dec 31, 2012
3,221
1,326
Best thing to do is to go to your dealer and get a rear remote kit for your tractor.
Greg5278
Kubota 3901 HST
Feb 9, 2017
Lambertville, NJ
That was I was originally thinking, but it's more costly with Kubota Parts.
I have been told that I can lockout the FEL Control, and connect the Splitter Lines to the Loader Quick Connects.
I won't be using the Tractor at the same Time as splitting Wood.
Thanks,
Greg
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,434
80
Rocky Face, Georgia
I added remotes to my L3000. Took the supply line from the loader and went into a valve then back to the loader control. When the remotes aren't in use the fluid just passes thru like it's not even there. Valve came from TSC and everything else came from hyd shop. If I was going to change anything I would have installed a double valve so I could run 2 sets of remotes if needed.
