Injection pump
brooster
B5200, BX2360, L3940, Z781i KW
May 15, 2021
68
Troy NC
I have received a replacement injection pump for my Kubota L3940, my question is if changing one pump for another is the only adjustment the shims? I am going to also order injectors and replace them at the same time, it appears that I am still getting fuel in the crankcase, I have been hesitant to run it for fear of damaging the engine, it only has 700 hrs on it.
rentthis
1,010
25
summerville,sc
I can't think of a route for fuel to get from the injector pump to the crankcase. Are you sure your fuel pump isn't the culprit?
brooster
May 15, 2021
68
Troy NC
I have been told that fuel can get past the seals in it, I have replaced the lift pump, the first replacement pump was leaking from the bowl so replaced with a second one, but what little I have run the tractor the oil level still seems to be rising
Edke6bnl
B7800 Kubota, case 1840 Skidsteer Ford 3500
Mar 31, 2022
260
143
Agua Dulce, California
My old Ford tractor would fill the oil pan with diesel. I made a point of closing the valve from the fuel tank and it stopped. No sure how it got pass the injector pump and injector. Unless it leaked through the injector housing to oil pan
brooster
May 15, 2021
68
Troy NC
My tractor has been sitting for about two weeks now and oil level has remained the same, so this is happening while running
#40Fan
411
281
Not uncommon for a common rail high pressure pump to leak into the gear case through the front seal.
brooster
May 15, 2021
68
Troy NC
So back to my original question about the pump, is there any other adjustments on the pump other than the shims between the pump and the block?
9,139
No other adjustment necessary, just put back all the old shims and your good to go!
Oil in these will always smell like diesel, and it's more common for the hydraulic pump to leak at the seal and put hydraulic fluid into the crankcase than it is for diesel to get by the Injection pump.
Mark the dipstick on the hydraulics then run it a while and recheck, it will only drop a little to rise the engine level a lot.
9,139
Leaky injector very possible
No it's not, a leaky injector would not put fuel in the oil while running, at least not with it running properly, and it would be smoking like mad!
And injectors only have pressure and flow when the engine is running, not when it's shut down.
brooster
May 15, 2021
68
Troy NC
Wolf man, I thank you, you have been most helpful, I will check the hydraulic fluid, where is the hydraulic pump on this tractor?
9,139
The hydraulic pump is directly behind the injection pump.
brooster
May 15, 2021
68
Troy NC
Is there anyway to determine whether it’s diesel or hydraulic that’s leeching into my oil? I did take and save a sample of the oil when I changed it after my runaway.
brooster
May 15, 2021
68
Troy NC
Also and I don’t know if this will help, all I run in my tractor is off road fuel so it has the red dye in it, would this show up in the oil?
9,139
You would have to have a sample tested, even then it's hard to determine if it's a normal residual level of diesel, oil and diesel mix really well.
Nope the off road dye won't help you.
Really the only way to determine what it's doing is to monitor levels.
How much is the dip stick gaining, in lets say 8hours of run time?
brooster
May 15, 2021
68
Troy NC
I have been hesitant to run it much, I check the oil and twice have drained enough to keep it from being over-full, the last time I got it about 1/4” below the full mark. I’ll try and run it some tomorrow and check levels and time and let you know. Thx again!
ferguson
L3130
Jan 19, 2022
321
125
w.v.
Fuel pump also & understand this quiet common
2,304
Replace the seal in the hydraulic pump and see if the engine oil level stops rising is probably the easiest way to know.
