Is there anyone out there that knows if I can increase the HP on my m110DTC. Believe it’s the 5.8L kubota engine.
Welcome to the forums!Is there anyone out there that knows if I can increase the HP on my m110DTC. Believe it’s the 5.8L kubota engine.
Should be big enough, certainly not a 'hobby' tractor.Welcome to the forums!
I am sorry for the lambasting you are going to get for suggesting that kubota engineered something that is under powered.
YOU WILL BE TOLD TO BUY A BIGGER TRACTOR.
Nearby farmer who does the hay on my land (and many others) once used a bale bandit. It was a wonder to behold when operating properly but he had lots of down time and finally replaced it with a large square/multiple small square unit that is much more reliable.I still want to see a rake / baler combination. Never heard of that. Only thing close to that I've seen is a Bale Bandit or a Bale Baron and it takes some pretty serious tractor to run one.
They are out there for large applications. Looks like a lot is going on and it needs to be very flat fields. Youtube it and you can see them.I still want to see a rake / baler combination. Never heard of that. Only thing close to that I've seen is a Bale Bandit or a Bale Baron and it takes some pretty serious tractor to run one.
