I use my tractor a lot less than you guys do. I did the 100-hour service today, along with the 50-hour that I carelessly didn't do when I should have. Everything was fine. Ran for 20 minutes around 2k RPM, let it cool & rechecked fluids, etc, everything seemed to be fine.
Until I tried to move it. Started up again ok, but when I lifted the 3-point, I heard a pop/clang/bang sound (which just may have been the implement) and it stopped. Master system warning flashing and E-20 code ("Communication Trouble"). Looks like I'm going to need to call the dealer
What could I have done wrong that would result in that?
Confession time:
I'll add one more bit of info, since it's what I suspect: A while ago when I was having starting problems (my first thread here) I had been messing with the PTO switch wires while trying to diagnose the trouble. I tried to set those right today, but I noticed after this happened, they had touched the frame (so, grounded). That seems to me a very likely cause. (I had intended to wrap the wires but I got sidetracked and hadn't gotten back to it).
So, was it a potentially costly screwup from my messing with the wires, or do you think I messed up something else?
Confession time:
