I ran out of fuel, help
mito352003
Paw Paw, Michigan
I know better, but today I ran out of fuel in my L2501 while mowing. I have topped off the tank but after many attempts it only turns over with obviously no fuel getting to where it should be. Is there a trick I should know? Or do I just keep turning it over until the fuel gets through. I am cautious about haveing the starter overheat with to many attempts. Terry
DocGP
117
SE TX
Went back to edit the much better advice from below. READ THE OWNERS MANUAL.
I am a fool for not putting that first.
Won't start until you crack the injectors/bleed the air from the system. Don't just keep cranking. I am sure there are videos on how to do it. It isn't hard, but is necessary.
Doc
6,445
Go back to your owner's manual for guidance!!!
Different Kubota's are bled different ways....I don't know yours, so I'm not going to guess. Mine just runs the lift pump for 20 seconds, and let er' rip....
If you loosen the injector lines incorrectly, you could cause irreparable damage to the IP, requiring a rebuild of the pump.
3,116
I was going to say the same thing about the injector lines for bleeding.
If I remember right, DO NOT loosen anything at the pump end. Loosen at the injector end.
MOST IMPORTANTLY, read the manual before doing anything!
6,445
BINGO! (y)
I forgot to mention some models have a simple bleeder right at the IP...don't need to open any lines, just like cycling the electric lift pump on a BX.....
To the OP, as much as an Operator's Manual is important, if you're apt to do work on your tractor a Workshop Manual (WSM) is more important.
You can get both at www.kubotabooks.com
Rcflyer330
Kubota B2650 Cab, B2779 Broom, B2782B Snowblower, RB1672 rear blade
Oct 14, 2019
111
61
Traverse City, Michigan
If you have a smartphone you can download the my kubota app and access the owners manual there.
mito352003
Paw Paw, Michigan
Thanks you everyone for your advice. I went to you tube and Messicks had a video on there about this situation. They said that the older tractors you would have to deal with the injectors, but no longer. Just fill it up and wait for the fuel gets to where it needs to be. After many attempts with rest periods to make sure starter didn't over heat she started and it took awhile to get the air out. Lesson learned don't let this happen again. Thanks again
6,445
Ford - - you da man! :geek: :geek:
Creature Meadow
Sep 19, 2016
1,065
140
Central North Carolina
Glad you got it back running.
I making a label to go on my fuel gauge glass that says reminder to fill up and placing it at the half full mark.
My standard practice is to never let it get below 1/2 tank but a little reminder will keep me even more reminded!
Good day OTT.
