I Imkabota New member Oct 21, 2019 2 0 1 Butler pa May 24, 2021 #1 lY warm but it seemed hot to the touch after running a few hours. Is this normal
85Hokie Moderator Staff member Lifetime Member Equipment BX-25D ,PTB. Under Armor, '90&'92-B7100HST's, '06 BX1850 FEL Jul 13, 2013 10,447 2,227 113 Bedford - VA May 24, 2021 #2 Where are you feeling the heat specially? What other pieces of info can you give us? Range selector, speed of cut, RPM'S?
Roadworthy Well-known member Lifetime Member Equipment L2501 HST Aug 17, 2019 1,649 526 113 Benton City, WA May 25, 2021 #3 Remember, on a hot day any metal surface can be hot to the touch. Lines carrying hydraulic fluid will be a bit warmer than the ambient temperature. Please describe your issue in a bit more detail as Hokie asked.
R RCW Well-known member Lifetime Member Equipment BX2360, FEL, MMM, BX2750D snowblower. 1953 Minneapolis Moline ZAU Apr 28, 2013 8,468 4,168 113 Chenango County, NY May 25, 2021 #4 Several times, folks on OTT have cited HST systems can get to ambient temperature plus 100 degrees F, so that's pretty hot. Be curious what the answers to Hokie's questions are as well.
mcfarmall Well-known member Equipment Kubota M5660SUHD, Farmall C Sep 11, 2013 1,385 1,657 113 Kalamazoo, MI May 25, 2021 #5 If you smell burning paint, it's getting too hot. Many industrial hydraulic units can run up to 140 F and automatic transmissions over 200 F.
