Hydro Transmission question on a BX.
kris77
105
CA
Just brought home a nice 2370 with FEL and 54" deck. I have a question about the hydro.
If i'm going down a hill and let off the pedal is the tractor supposed to stop completely and the hydro hold it back or is it supposed to slow down to a slow creep and gradually go down the hill?
RonBoyBX25D
B2650, LP Grapple, Bro-Tek spacers, QH, Box Blade, Landscape Rake, RB, and 1560G
Aug 1, 2015
477
Minneapolis, MN
It depends on how steep the hill is, slight grade my BX25 will stop and hold as it increases it will roll without the parking break on.
Not sure if that is how they are supposed to work, but all the HST that I have driven work that way.
kris77
105
CA
Mine starts rolling on a gradual grade. I think it should hold its ground on a little hill. I'll have to check things out. I'm wondering if they filled the transmission before they put the loader on and forgot to refill once the cylinders on the loader were filled. Maybe its just low???
I"m not real sure how its supposed to work.
TripleR
Sep 16, 2011
1,911
SE Missouri
All of ours stop and hold unless it's pretty steep the it will kind of move every 30 sec or so a few inches.
2,812
Weight of the machine has a lot of bearing on the situation. A BX might stop on the hill side at 20d slope, where as a 25D might also take a few more feet to stop and then creep a bit. The gravity of the situation does not change but the friction and angular momentum does as the angle changes. Plus worn seals and exact pedal placement will have an affect on the stopping distance. By BX-25D would stop going down a 22.5d hillside......but that is in 4wd drive, it would break traction and start to accelerate if not. Even my B7100 will "creep" a little on a slight hillside, but the pedal slop has more to do with that.
I think all will creep - over time and increase of angle.
kris77
105
CA
This is a brand new out of the crate tractor. less than 2 hrs on it. It wont hold itself back on a 10 degree slope. It doesnt "creep", it rolls slowly down the hill. It wont hold itself in my regular yard without setting the parking brake.
I'm guessing something is wrong here.
TripleR
Sep 16, 2011
1,911
SE Missouri
Probably just an adjustment, my first BX did the same thing, instead of creeping forward, it would go backwards. The dealer adjusted it and problem solved.
kris77
105
CA
Anything i can look at myself before i call the dealer on Monday? Dealer is quite a ways away from me.
TripleR
Sep 16, 2011
1,911
SE Missouri
You can try a light duty grease on your zerk for the HST pedal and I "think" there may be return springs under there, can't hurt to crawl under and look round, had a stick jammed in one of mine.
bcp
BX2360
Apr 20, 2011
644
79
SW WA
Mine will "creep fast" in Rabbit. In Turtle, it nearly stops and barely moves.
What is your in?
Bruce
kris77
105
CA
I know i was in high gear when i tested it in my yard. I'll have to try it again in low and see if it makes a difference. Thanks for the tip. I'll check it out tomorrow after work.
Grandad4
Apr 5, 2016
381
125
Greensboro, NC
Just wanted to say if you're dismounting the tractor, relying on the HST pedal to hold the tractor on a hill is pretty risky business. If there's any measure of slope, I'll drop the loader and any 3 point attachment to the ground and/or set the brake.
As others note, on level ground, the HST should go to a neutral, stopped position when you remove your foot. It shouldn't creep. On slopes, that's another story, and a bit of drifting downhill would be quite normal.
kris77
105
CA
I've found out that the older series, the 50 series and some of the 60 series are set up different than the 70 series. The 50 series will through you into the steerng wheel if you let off the pedal. Customers complained and they loosened up they hydro for the following years. Slow creep down the hill is normal in high range and even slower creep down the hill is normal in low range. And it gets even slower in 4x4. But according to 3 different dealers, its normal for the 70 series to do this.
RonBoyBX25D
Aug 1, 2015
477
Minneapolis, MN
Thanks for the update, good to hear how a tractor should be working.
Bmbbm
Bx2370 land pride box blade 60"mmm kubota fel
May 29, 2016
282
Chillicothe mo
My BX2370 will stop dead in its tracks when you release the pedal. I only have only had it a few months with about 12 hours on it. I've never let it set to see if it creeps forward. Good luck with your new tractor. I bet it just needs a minor adjustment.
kris77
105
CA
If i'm crusing along on flat ground and release the pedal it almost stops dead, if i'm on a hill going down hill and release the pedal it almost stops dead, then slowly creeps down the hill.
I was under the impression it was supposed to stop and hold itself back on the hill. But i'm starting to find out that this isnt the case.
I will say this...While mowing yesterday, i found out that having the back tires filled makes for one bumpy ride. I didnt realize how uneven my yard actually was...lol
BAP
Dec 31, 2012
2,913
1,027
Loaded tires shouldn't make the ride any rougher if they were loaded correctly and have the correct air pressure. The tires should only be loaded until it just runs out of the valve stem at the 12 o'clock position. That leaves enough air space to allow for cushioning. Chances are if your ride is rough there is too much air pressure in the tires.
William1
BX25D
Jul 28, 2015
1,205
402
Richmond, Virginia
Taking your foot off the HST pedal, the tractor will still move a few feet and usually stop. Foot off the pedals should be thought of as a 'Neutral' and not 'Parked'. Then you apply the brake (and set the parking brake if you are getting off).
If on a hill, be sure it is in 4WD to transfer braking effect to the fronts too. Great advice about lowering all implements to the ground too.
kris77
105
CA
Filled with a washer fluid type solution. Methanol/water maybe? This tractor is WELL worth its price. I've mowed 3 or 4 times already on different parts of the property and its did wonderful. The FEL i worth its weight in gold. I've already moved about 10 tons of gravel and another 10-15 tons of dirt i've had piled up around the property for years. Its making fast work of anything I throw at it. I haven't gotten the hang of taking the bucket off and putting it back on yet....Takes me about 15 mins or so to put it on and around 10 to take it off. But i'm learning.
What grease should I buy for my grease gun? I'm guessing a high temp grease instead of the $1.49 tubes from wal mart.
