Hydraulic question
10,605
Does it have rear remotes or a loader?
10,605
What model loader do you have on it?
These larger Canadian equipped tractors have several different options of loaders.
OlFerguson
4440, 1120D
Jun 1, 2017
197
12
m46. It’s a cable run alo /quicke. The direct replacement is the same one Massey and new holland uses on their machine . It’s open lcs. Ergo drive .
6,875
What sort of "issues" are you having with the control valve? Thats essential information for determinijg how and where to test it.
I dont know what "open lcs " means. . Case and Massey often have closed center load sensing (CCLS) hydraulic systems.
Can you provide a link to the parts diagrams for the valve?
6,875
OK - found it.
Loader Control System (LCS) ERGODRIVE
Loader control valve by ALO. Thats a sophisticated device and above my pay grade. You might want to purchase and read this:
BX23-S,57 A-C D-14,
6,237
hmm..cable run valves ..
I'm wondering if it's 'junk' in the cables or 'stretched' cables that's causing the problems ?
There 'should' be some form of tensioning adjustments.
