Hydraulic pump
stabota
Kubota Sunshine Tractor L1-R28
Aug 18, 2019
10
castlegar, bc, canada
Need replacement for input shaft on hydraulic pump. P# 31351-7633-0. This is on a kabota L1-R28. If anyone has any idea where I might find parts for a grey tractor I would appreciate your response and input. Thank-you.
Roadworthy
L2501 HST
Aug 17, 2019
1,647
529
Benton City, WA
I had a gray market Mitsubishi. I had reasonably good luck finding hydraulic pumps and other parts on eBay.
6,257
Are you 100% that's a good Kubota part number ? Google didn't like it and normally it'll find a Kpart 1000s of times.
Other trick is to find a 'nongray' equal tractor that uses the same part, then order THAT part number from dealer.
10,778
You can't just replace that shaft, it's a matched set, you need both shafts and gears and both sets of blocks.
You're better off replacing the whole pump.
Post some pictures of the pump and I'll see what I can find that matches it, there more than likely will be several non grey models that will be the same.
billrigsby
Mar 17, 2015
1,050
247
Florissant CO USA 8213'
www.facebook.com
6,257
I had a 'grey ' tractor and local dealer would NOT work on it, tech said 'use this model(us version) for parts,to order'. did that ,installed them myself. Made sense that most parts will fit several models.
billrigsby
Mar 17, 2015
1,050
247
www.facebook.com
No they will not, can loose the franchise doing so.
Surprised they went that far, locally if they even know
you are buying parts for a grey you would be blacklisted.
stabota
Aug 18, 2019
10
Thanks to everyone who replied. I did call lady in Sask and she told me which unit would match. Pump is on order, should be here soon. Thanks again, I really appreciate the input.
fiannakrog
Toronto
Hi, have you considered any options on Amazon yet? I have heard that it is very often possible to find the necessary parts for cars and other cars at good discounts. I do not understand this myself, as I am planning to buy my first tractor for my parent's farm, but I hope I will soon know more about this area. So far, I can advise you on the service my father constantly uses if something has broken; this is the company https://www.truck1.eu/spare-parts/hydraulic-pumps/hpi-xxxxxx-a2976648.html. They sell spare parts for trucks and other car models, so I think you will definitely find what you need.
bucktail
Jun 13, 2016
1,288
216
MN
I thought that was just a USA thing that didn't apply in Canada.
