Hydraulic Pump Seal
guiznev
front loader, tilling, plough
May 16, 2014
France
I have a Kubota grey import (manual says it is a B1500 - 1600 series. The hydraulics in the front loader blocked leading to over pressure and thus blowing the seal in the pump. Result hydraulic fuel in the engine and then on my lawn via the breather tube. I am in France so as soon as I turn up at the dealer they will not supply without a serial number, which I don't have. Can any one out there help?? At the moment it runs beautifuuly but I can't use my front loader.:(
11,182
Post a couple pictures of the pump and I might be able to tell you the seal.
Your tractor has a D950 engine in it, and it could have a couple different pumps on it.
guiznev
May 16, 2014
France
Thanks for the quick reply - some photos attached. On the cover of the pump is stamped GP - 3495B (not certain about the 9 because of scratching) on the end casing 042. Diameter of spindle in about 1/2 inch. The hole measures just over an inch. If it helps I can take out the seal and give you more accurate measurements.
guiznev
May 16, 2014
France
hi Wolfman,
Some additional info - I removed the seal which is clearly bust. It contains a circular spring which is also damaged. Dimensions: ext diameter 2.75cm, internal 1.35cm (sorry for metric but I don't have ameasue in inches. There is also a code on the seal - AE 0526 A, if that means anything. Photo of seal attached.
If you recognise this can you supply?
11,182
If Vic can't set you up, or you can't get one locally, just give a shout and I'll help you get one.
guiznev
May 16, 2014
France
Thanks Vic and Wolfman. I'll try locally and let you know what happens.
