I have a L2550 GST. I just finished tearing it down to fix and repaint it. I had everything of the tractor. There was only motor, transmission and axles left. While apart I also took apart the rear axle to change a seal. Change the hydraulic filter and put in new hydraulic oil. This weekend I started the tractor and the 3 point hitch wasn't going up.. Made sure the knob under the seat was opened. Connected the cylinder for the plow to the valve block and the cylinder was only moving a little bit. I figured something wasn't put together properly. Below is the manual that show how it's supposed to be connected. And the other 2 pics show how it's connected. It appears to be correct. The hydraulic block itself or the lines that go back to the pump were never taken off. Any idea were I should start looking.
