Yooper,
What info would you like? My reservoir is 52 gallon, custom fab.
You will need a speed increaser, 540 rpm increase to 2025. That will spin a pump fast enough for desired output. Mine is 33 gpm @2500 psi, but that req's min 40 pto hp. Doubt you need that much flow. The prince pto pump will provide 20 gpm @ 2200 psi, should meet your needs and the speed increaser is self contained. You need simple frame to support reservoir, filter, recommend a cooler ($500 12V) pressure regulator. These are stupid expensive to buy but reasonable to build. I do not use a valve to activate, just engage pto. With wood processing you might want to add a valve at unit. If you need any part #'s I'll try to help. You could buy a reservoir, less $, need 25 gallon, w/ cooler @ 20 gpm pump. Pump in photo is just resting on reservoir. It piggyback mounts to increaser under tank when complete. Hoses not yet connected. Your stump grinder is
Front mounted? @FEL. To be mobile, power unit occupies your 3 point. More photos added.
EDIT: Cooler info below, performance uncertain. Review the mfg website for heat dissipation. Thia application will use 26 gpm of the total capacity of 52 gal tank. See screenshot for vendor and mfg. Pump max is 33 gpm
